RichardG
If at first you don’t succeed have a cup of tea.
My MIL wanted a small table for hubby to put his mug on so I thought it would make a good turning exercise for me. They have ercol furniture so copied the simple 2 taper style leg and turned a small top which I then bored 3 angled holes in for the leg tenons. This is the first turned project I have done appart from practice bowls, spindles etc. It’s made of oak as that’s what I had.
I found the legs hard to do, creating a smooth taper was extremely tricky and I ended up use a rouging gouge to get the approx shape, then a combination of planing cut with the skew and then a flat scraper. I also made the mistake of not starting with the legs all the same length so once I’d trimmed them to length of course the bottom of the one leg is slightly bigger diameter that the other that didn’t need trimming.
Anyway I digress, the reason for the post was suggestions on how to make it look better proportioned, it just doesn’t look right to me? Perhaps thinner legs? Perhaps a shelf halfway down? Or will it never look right because of the design? It’s not assembled so I can remount and do some more work.
