The_Wood_Basher
So I thought I would share my way of creating a whitewash on furniture as it is different to others!
This look is not for everyone and its also not easy to undo should you decide at a later date that you dont like it, so keep that in mind. However it is a good way to give a whole new look to older furniture, you can also hide marks and defects during the process.
What you will need:
Sand paper
Wire brush
Baby wipes
White paint
clear cloat
Painting supplies
The process is actually quite easy, it only has 5 steps. However it does take some time.
Step 1:
Sand the whole piece of furniture, if it already has a varnish then you will need to sand that but not necessarily remove it all. Its important to sand with the grain. At this point you can also make any repairs you feel it needs, feel free to use filler as we can hide this later.
Step2:
The sanding will have closed the pores of the wood and we need to open them back up, Give it a good scrub with a NEW wire brush. Make sure it is new or at least very clean! As with the sanding be sure to brush with the grain. Once this is done, vacuum all the surfaces and then wipe them down with a damp cloth.
Step 3:
Apply the paint to a side or small area to work on, be sure to get plenty on and not to worry too much about the grain. Its most important just to get the whole piece covered. Leave about 10 minutes or until you see the surface start to dry.
Step 4:
This is the part where you create the beech look, so get the baby wipes and start removing paint to reveal the wood underneath. You will see that the paint soaks into the wood more in certain areas and that is ok. Use the brush to bring back the grain of the wood and remove the wipe marks from removing the paint. How you decide to leave the piece at this point is how it will look once finished. Leave to dry overnight
Step 5:
Once dry go over the whole piece with 400 grit sand paper and then a damp cloth. You can now add your clear coat to finish it off. Apply 2 coats if needed.
For the once who prefer to watch a video of this being done I have put one together here: https://youtu.be/crBPdnh9QW8
Whats your take on the effect? have you ever done anything like this?
