Thanks for the replies
petermillard":2gmzwn6f said:
I think my first consideration would be that 46" is a pretty wide span - I'd think hard about putting a central divider in there for support, whilst at the planning stage.
unless you let the base of the face frame run all the way down to the floor, and fix the skirting to that, of course...
Not sure if being a ’hand tool woodworker’ prevents you from using labour-saving niceties like routers, but the housings could be made by lining the inner sides of the carcass with e.g. 6mm stock, as appropriate for the shelf positions.
As for fixing the face-frames - if the units are to be painted, why not pin them on, and fill over the heads??
I agree that it's a wide span and I think a central divider is a good idea. I guess that rules out any kind of adjustable shelves.
That was the general idea with the face frame; run it to the floor, flush with the front of the alcove, and fix the skirting to that.
Not having a router prevents me from using a router! I'm sorry if I gave the wrong impression by saying I'm a hand tool woodworker. It's not a "lifestyle choice" or anything like that, it's just the way I like working. I certainly don't have the room in my shop (shed) for things like a table saw, router table, etc, and my close neighbours wouldn't appreciate the noise. Anyhow, I don't find housings particularly difficult or time consuming by hand, if that's what it takes.
No skills":2gmzwn6f said:
All good stuff there. What do you want to make them from and where do you draw the line at hand tool/power tool use?
I don't know how face frames were made in the old school way, M&T I'd guess - a through dovetail might be a neat look, but plenty of work.
Not sure what material to use yet. Redwood would be cheap and easy to work, and it's going to end up painted anyway. However I'd probably have to edge joint lengths together to get shelf-sized stock. If I have to I could use ply, but I'm not keen on ply and I'd have to get it cut at the yard. Again, any advice on this is welcome.
I'm happy M&T'ing a frame together, but how do I gauge the length of the top and bottom rails, being as the stiles will be getting scribed?
rafezetter":2gmzwn6f said:
Sorry if this sounds a bit like granny and eggs but, just my thoughts:
30mm seems like a lot, but I've met alcove walls with larger out of true.
I'd agree with making the base face-frame deep enough to accommodate the skirting - if it's really deep like 8" you might even want to consider a sneaky drawer or drop flap or something - you could use that space to put a lighting power unit in and run lights to the top 2 shelves for display, because of the span if you wanted to hide any wiring, you could make the central partition out of a 6mm ply hollow sandwich with thin blocks inside to allow a wire to be threaded between.
Another option you may have already thought of is deep shelf faces - thicker than the actual shelf stock, to give a lot of extra stability and strength if you don't go for the central partition option.
Any egg-sucking advice is gratefully received
Our house was built in 1957 but in places it is shockingly out of truth...
Interesting idea on the lighting, I'll see what Doris thinks of that.
I was mulling over the idea of deep shelf facings, a bit like aprons on a bench. How deep would they have to be in order to do away with a divider?
