Reply to thread
Some bit of paper is not going to hang a door or fit a staircase,  you might be the most highly qualified carpenter around but if you cannot do the job and meet expectations you are not going to be much use as you will never learn in a classroom what you will on the job.  Your problem is that you need your current job for income and just taking time to go on evening classes is no good without the experience and is where a youngster living at home can work with a skilled bloke and do the theory.
