Hi Martin
I went for the Hammer for 2 reasons one was cost, and the main one was the foot print as I had to fit it in between an end wall and the door.
I had to fit it into a space of 3m, but if you have another 600mm or so you will be able to pick up a second hand one, for not alot of money and then up grade as money allows.
The Hammer is a lot more light weight than the Felder machines but for me on my own is fine.
I plane, glue and then sand, unless it is a really wide top and then I do it in two halves and finish the centre joint by hand.
There are other makes such as Rojek which Axminster sell which may be worth a look.
I would also talk to other dealers as there will be better machines around than the Axminster through feed.
Tom
