And just hope that you don’t have woodworm burrowing their way through the sapwood – that pale white strip just under the bark, it’s that bit softer for them to get their teeth into. It’s quite common to find live grubs just where the bark and the sapwood meet as well. Ian
You may find as a lot of people have that the next time you pick your detector up the battery is flat, some drain the battery when not in use so best to disconnect it. IanWood moisture meter arriving tomorrow.
https://www.amazon.co.uk/Wood-Moisture-Meter-Detector-Humidity/dp/B0886JCGL5
