engineer one
ok so i confess i bought a shoulder plane from LV at tool show 2005, but i had also looked at the LN versions and in the catalogue, it mentions a nicker on a rebate plane.
so my question is what is the real use for a shoulder plane?
should you be able to cut a shoulder for say a tenon from the top down,
or is it only for use after you have cut to the length line.
the reason i ask is that i also have a clifton 420, which i have sharpened and honed, then tested. i found it cut a ragged edge at the vertical intersection with tear out. was i expecting too much or is this not the way
to use a shoulder plane. i must say i thought the fact that the blade was able to move to the side of the body meant it would cut that edge better.
again a piece of the learning curve, since i assume you might get the same problem using a rebate plane unless it has another cutting edge.
and finally does the nicker actually make any difference has anyone tried and do they know??
paul
paul
