now then all!
Gill recently opened my eyes to stacking so i thought i'd give it a go, i 1st tried a double and all went reasonably well but this morn tried a triple and noticed just how hot my blade became and how rapidly became pretty useless. i do use a wax type lube every so often but think i could have it permanently pressed up against the blade in this case and still burnt it out.
the wood is a birch face ply aprox 3.5mm (ea)
i used a reverse skip tooth RV5 (could this be wrong choice)?
i can only guess my speed ...prob about 800rpm (am i all hell and no notion)?
i was wonderin is it something i'm doing wrong or is it just the fact there are alot more teeth in contact with the larger surface area of wood doin a lot more work?
i'm gonna persevere and try again pretty soon as i've found with scrolling there's a lot of trial and error but jus wondered if there was something totally obvious i'm doin wrong here? so if anyone could give some advice and save me some of my resources and time (it took me probably as long to do as it would have to do two double stacks) (and the bottom piece was damaged a bit and very rough)
i'd be very grateful
many thanks,
Jay
many thanks,
Jay
