Hi all
Just started making some chairs using my domino to do the rail to leg joints. I'm finding that the glue surface area is a bit limited using the supplied domino sizes so I reckon I'm gonna make some wider ones myself - 8mm thick, 54mm long, and 50mm wide. This gives a much larger gluing area (30% more) than say 2 x 8mm dominos, 50mm long and 21mm wide.
I'm just gonna use scraps of oak mainly that I have lying around, thickness them to 8mm, round over the edges, put a groove in the middle for glue to escape and bingo!!
Surely they be as good as the Festool ones?? Or is there something special about them??
Regards, Andrew
Regards, Andrew
