Hollowing tool
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Hi all,
I`m looking for some advice on hollowing tools. I`ve not done any hollowing before, but after seeing the fine examples on the forum, i fancy giving it a go.
So what would you recommend as a "first hollowing tool", that would be user friendly to a novice, & not break the bank?
Cheers.
Hi James.
As a start make a 'Oland' tool. Basically just a steel bar with a small HSS bit secured to the end. Fairly simple to make, and IMO the least expense. You can make them straight, bent, in fact any shape you want.
CLICK HERE
Google Oland tool and you will get plenty of choice.
I started off with the Sorby Multi tip hollowing tool. I found it easy to use and the flat section of the bar allowed controlled cutting edge placement (you always know the orientation of the cutter). It can also be used as a shear scraper so if you need to justify another purchase you can :D
It also comes in bent arm form but I've never used that one.
These days I mainly use a Munro hollower and a selection of other tools that I've made, which are mostly based on the Sorby system and use a screw attached cutter that I can quickly change. These tools are all based on round section bar (mainly 1/2" and 3/4")
The advantage of round section is that you can approach the surface with the cutter angled down, away from the surface and gently roll it up to begin the cut.
Price wise these can't be beaten as £10 bought me enough steel to make 2 tools. I usually cut both ends flat and drill and tap holes to take hex bolts that will hold down the Sorby bit holder at one end and the Munro cutter at the other. The end that takes the Munro cutter can also take small extensions that I've made which allow a curved neck to be formed.
I mount these bars in my Munro handle but I also have 3/4" tool mounted in a long wooden handle.
For cutting tips I use a combination of masonry nails, cut up planer blades, the Sorby tungsten tips and HSS scraper tips.
Given the cost I'd say go the home-made route and perhaps buy just the Sorby cutting tip and tool holder if you need them. You should start of with small projects so shouldn't need anything wider that 1/2" bar.
Hope that helps
Duncan
I have a Stewart System (aka Sorby) hollowing system that is surplus to requirements.
I have the arm-brace, curved hollower with both cutting tip and shear scraper plus a slicer used and an 'industrial parting tool' that will easily take cones out of bowl blanks - not quite as flash as the curved coring devices but then not the same price either!
I am at work at the mo, but could post picys tonight if it was of interest?
Let me know.
Simon.
James,
I have put some photos up on a seperate thread rather than hijacking yours to sell my stuff!
However, as you gave me the idea you have first shout until tomorrow!
BRgds and happy turning!
Simon.
James.
I did a few small hollowings using the Sorby Multi tip tool as Duncan describes,and found it to be a very safe tool to use,especially with the flat section shaft.Biggest piece i done with this tool was about 6" long which is it's max.
I also like using the scraper that comes with it as it does give a very good finish.
But i soon went and bought the Roly Munro tool which i am still trying to get to grips with. :roll:
Thanks very much for the replies so far lads, it`s given me some options to mull over.
Thanks for the offer of the Stewart system Simon, but as i`m still looking into the different systems & am not yet sure which way to jump, i`ll pass this time. Good luck with selling it though.
Off to work now for the week :( , but anymore info will be gratefully received when i get back next Saturday.
Cheers for now.
