Hello there, I have made something that started clean and since sanding has become a mess. I have filled in the areas that need to be fixed and thought I could sort it out by making a template out of plywood.
The cutter is 12.7mm, the closest I could get to the size of the bush.
It works, but because I am using a router bush it doesn't hit the edges.
Can someone please tell me how I can achieve this? Are there slightly oversized holesaws that will make up the difference or router jigs that make the holes the correct dimensions?
