kezzer
New member
Gents & Ladies,
I'm nearing the end of my 1st big project, the split top roubo bench and have created myself a problemette that requires a bit of sense to solve.
I have bought 3/4" benchdogs and holdfasts and have test drilled a couple of 19mm holes in some stock just to see the "fit" of these clamps. For me, they were a little on the tight side so have gone with 20mm holes for the holdfast holes in the leg. Problem is, they will not hold fast, they won't grip. I did try a test for them in 2" stock which worked fine but it seems in 3.5" deep legs and I'd assume, my 4" top the holdfasts won't grip. Not a problem for the dogs since they sit in with a side spring.
What I'm looking for is a remedy. I will obviously do the top with 3/4" holes. Yes I could drill more 3/4" holes in the leg but is there something else I could do with the holes I have, maybe add some 1mm or .5mm shims that may help or even with the holdfasts, they are Sjobergs Holdfast ST03 from Axy?
Thanks in advance.
Keri
Thanks in advance.
Keri
