This is a bit of a newb question, but worth asking anyway.....
The dimensions given for hinges when buying online baffle me (slightly). I get that the given width dimension is the overall measurement with the hinge open, but I don't know how much to allow for the barrel section. Or in other words if I want butt hinges with leaves to fit a particular thickness of board is there some standard method to calculate what this will be (considering only some places give a dimensioned diagram)?
For instance, I am currently building a pair of toy chests using pine which has finished at about 19mm thick. Will the following be suitable? The lids are about 34" x 17" , so I was planning 3 hinges each (must be as near as possible indestructible).
http://www.toolnut.co.uk/products/cabinet_fittings/hinges/Broad_Butt_Hinges_-_38mm_x_63mm.html
Gareth
Gareth
