Mrs C
Any recommendations for a high torque cordless drill that doesn’t cost a fortune?
sammy.se":3l0txzcp said:I have the Makita DHP481 and it's brilliant
However, since I bought an impact driver, I've found the high torque needs for my drill have gone down.
Sent from my SM-G973F using Tapatalk
I had a 1500 cc motorcycle that only just matched that torque :shock: :shock:Nelsun":1vz3enxn said:The Makita DHP481 will turn the world (115Nm) and can be had bare for 145ish new if you have the batteries already. I've been meaning to list mine in the classifieds due to jumping on their 40v battery offer if that tickles your fancy.
It was a V twin low revving cruiser, but it could pull well over a half ton pretty smartish. 8)Phil Pascoe":1in7u3ij said:Mine was 167Nm. :lol:
I don't buy into that as both have their strong and weak points e.g. DeWalt stands, table saws and nailers (although Milwaukee and Hikoki appear better yet) are streets ahead of Makita, but drills, impacts and circ saws... not so much. It's horses for courses really.Phil Pascoe":2zgec3di said:I've spoken to a few tradesmen lately who have all said the new DeWalt stuff is better than Makita.
AJB Temple":3jj7rpq2 said:I'm curious. It's hard to imagine why high torque would be a pre-requisite in a cordless drill. Are you sure you need this? The disadvantage is weight, and when the drill grabs it takes your arm with it.
Trevanion":3qgstw3a said:Got any more idea of what you plan on using the ‘high torque’ drill for?
It's only just been added to their very latest drill: the HP001G. The only clip I've seen of it doing its thing is 5:40 in to this video of some poor guy endlessly drilling holes with one.sammy.se":wea51xp4 said:I was aware of that feature on SDS drill, they call it a clutch. My Makita cordless driver does NOT have that feature, as my wrist will attest.
Maybe they have since added it.
I see that this drill has a pretty substantial side handle. Just a thought but this could be extended in some way so that an assistant could take all the torque load.Nelsun":3soqw2d6 said:It's only just been added to their very latest drill: the HP001G. The only clip I've seen of it doing its thing is 5:40 in to this video of some poor guy endlessly drilling holes with one.sammy.se":3soqw2d6 said:I was aware of that feature on SDS drill, they call it a clutch. My Makita cordless driver does NOT have that feature, as my wrist will attest.
https://youtu.be/Q6ij9ScuoVc?t=340
That high torque Makita will be very adequate. I've used it to make holes in joists using an auger bit and it went through like butter.Mrs C":20shqtx0 said:Trevanion":20shqtx0 said:Got any more idea of what you plan on using the ‘high torque’ drill for?
Sorry, should have said. For putting hinges, holes etc. into field gate posts where it’s too far from the house to run a cable.
