High chair
jb94
11 May 2024
Rotherham
So the little man is now about to become a slightly larger little man and needs somewhere to sit to eat grown up food now.
We live in a small new build with next to no storage, and looking for some kind of high chair that either folds and tucks under a work surface I put up (max height 88cm) or is rigid and slides under the head end of the dining table and lives there (65cm to apron).
We’ve looked at loads of high chairs in person ranging from £100-£500 (yes you read that right) and between difficult to wash cushions or poor build quality or price or not filling the spec above we’ve not found anything!
Triptrap could fit the bill but is expensive and the necessary add ins soon add up. I did consider making the framework and just buying the attachments but looking at the instructions it fits in a very specific way to the frame that without a reference in front of me it’d be difficult to make a replication to fit.
Also was thinking I could make a stick chair style highchair (recently finished making a Windsor) but that took ~2 months to make (few hours a week) and I don’t have that sort of time.
Anyone have any suggestions for a quality chair that I could buy that’s sturdy and fits the spec or something that’s straightforward to make so I can get it made in a weekend in between daddy daycare duties?
Probably not a weekend project but the Victorians made some lovely high chairs. With the inclusion of a cunning mechanism, they converted into a low rocking chair.
I think there was on on the Repair Shop if you have iPlayer.
if space is tight why not use a clip on high chair it attaches to the table top and its small enough to use anywhere look on ebay
Make it in two parts, a short chair, and a table / plinth that the chair can drop on to for feeding, be used as a table for drawing on, and the chair fits inside for storage.
For general inspiration, WoodArchivist is always worth a browse.
https://woodarchivist.com/tag/highchair/
Or google 'highchair table combination'
The TrippTrapp chairs are ace and will last until your little one is 10ish. They hold their value so I'd buy a secondhand one on ebay and sell it for the same price in many years. However, they do not fold up and pretty sure from memory are taller than the end of a table.
I'd approach it by buying dowels and tenoning them using veritas tenon dodads(20mm dowel and 5/8 tenons work well.) £30 worth of dowels and beech...tadah. anything else that can be brought just buy.(say cushions, trays) I recall going into a cafe owned by a Japanese lady with a baby. "Got a high chair? No, she proceeded to tie him to a normal chair with an apron which was wildly effective!(it was called"the penguin"
I looked into these but it restricts you to the table if my wife needs him in the living room for instance.
This is a good idea, could be two part on legs with threaded rod like a snooker cue
I did look into triptrap, what they get you with is the attachments as they’re specific for the trip traps and can soon add up in cost.
I was considering doing this, basically like my Windsor chair on stilts.
What I’ve started doing yesterday evening was making a kind of A frame out of some scraps of oak in the garage to replicate this design:
https://sorenshouse.co.uk/products/...J1IMfR3uz2o79dkEbd4OHJYpYfAJ_zZxoCcWYQAvD_BwE
with the plan that you can move the footrest up and down and seat up and down for when he grows. 5 point harnesses I’ve found for £5 on Amazon and cushion £10 ish.
If it doesn’t end up being sturdy enough I’ll try something else but current spend is at £0 so worth a shot using this scrap wood first
A good easy way here is to drill using a forstner 1mm smaller than the dowel. Cut through the middle and this sits nicely around the adjoining dowel and a drywall screw make a strong and neat joint (pre drill)
So I started building an a-frame of sorts for this high chair and abandoned it in the end, just time pressures mainly as I work full time and he’d be old enough for a normal chair by the time I got round to finishing it!
My wife wants adjustability for seat position and footrest position etc etc (more complexity than I initially envisioned) so we’ve ordered this trip trap alternative should be here tomorrow.
It’s solid wood so at least if it needs a fettle it should be straightforward for me to modify.
But thanks for all the suggestions above cheers
