Philly
Hi All
There has been a lot of discussion lately amongst hand plane nerds on the benefits of the bevel up planes (i.e. block plane types, low angle jack, etc) especially when grinding the blades for a higher than regular angle. I have a L-N low angle jack, but as I use it for the shooting board (and want the benefit of the low angle blade) didn't want to try grinding the bevel to a higher angle.
As the blade is supported by the bed all the way through to where it exits the mouth (as opposed to regular bevel down bench planes where the last few mm are in the air) this gives more support to the cutting edge, resulting in less chatter and a smoother (read better quality) cut. At least thats the theory.......
I bought a Veritas low angle smoother recently and purchased the high angle blade to go in it (only £8 off that nice Martin Brimarc :wink: ) This plane is a real beauty-I was very impressed with the build quality and attention to detail. Please read Alf's in depth review for the details-needless to say, I love it. I ground the bevel at 42 degrees on the blade, and combined with the 12 degree bed angle gives 60 degrees.
My top "nasty interlocked timber" smoother has been the HNT Gordon plane. This too is bedded at 60 degrees. So, a competition has been forming in my mind...
Gave both planes irons a polish up to the best of my ability.
Plop a plank of nasty ovangkol on the bench and away we go......
(forgot to mention-the veritas has an adjustable mouth, like a block plane. This lets me close the mouth right down-and there is a stop screw to stop you dinking the blade. Fantastic-cheers Veritas! :wink: )
The Gordon happily swiped fluffy shavings off with no tearout. Good Boy!
The Veritas (try saying that three times quickly :lol: ) , with mouth closed right down, did the same. Yup, high angle+tight mouth+fine shaving=perfect surface in "un-planable" stock.
Don't know if you can make it out in the pic, but the shavings are 1 thou of an inch. That is fine (and also tells you the sole of the plane is pretty darn flat) You can see how tight the mouth is. I haven't shown the Gordon as the results were the same.
Now look at that-a perfect, gleaming finish. Sandpaper not needed.
So-to sum up. High angle planes are the real deal for tough to plane timbers. Personally, the Veritas is a lot easier to use than wooden HNT Gordon plane, although the knack is easy to pick up with a little practise. The Veritas smoother is a superb plane (at a good price-I paid less than £130 for mine) and the results speak for themselves. And of course, I still have the low angle blade ready for a little end grain use if I need it.
Hope this is of interest,
Philly
Philly
