Farmer Giles
The biggest tool in the box
My first lot of hex shank drill bits were the cheap two part kind, where the drill starts rotating in the shank, kind of defeats the object of the hex shank. You get what you pay for.
My next purchase was a one piece Famag set, this one. When I mean one piece, I mean each drill is made out of one piece of steel, I know its a 5 drill set
The only problem is that the shank does not have the large groove so it is retained in your average chuckless driver directly, it will fit but when you try to remove the drill from the hole it usually slips out of the driver. It is designed to fit in a bit holder, as per a screwdriver bit. This adds to the total length making them less than useful when working in small cupboards etc.
Any how, I have misplaced them, I've looked high and low, I'm sure they will turn up but in the mean time I have bought these Fisch ones, still one piece but with a sensible groove. I have a nice small 12v driver, yes I could just use a chucked drill, but while I'm making the kitchen I tend to use both pillar drill in the workshop and cordless in the house so two sets of drills are useful, one for the chuck on the pillar drill, and for convenience I though quick change hex shank drills would be useful.
Then I saw the following Famag short drills, I like the idea, shortens the overall length so I don't have to get the right angle drill out, but these haven't got grooves either, so by the time you have added a bit holder to your hex driver, you may have just used a standard drill.
Am I missing something like some Festool influence or is the design wrong? Not a major issue but I'm on the train to London and bored, pardon the pun
Andy
Andy
