I am planning to make a run of built in cabinets 3 metres long. I am hoping to make the cabinet top from teak/iroko finger parquet which used to be the flooring in my hall.
The plan is an 18mm MR MDF ground, veneered with the parquet ripped to circa 3mm, in a herringbone pattern. I'm after advice on a suitable adhesive, and thoughts on whether I need to counter veneer the MDF , and if so whether that needs to be more herringbone, or a cheap constructional veneer. I'll probably lip the top with solid timber.
Any thoughts, or even better experience of a similar project?
