Mutley Racers
Hi all. I hope you are well. I am after some advice. Can anyone tell me the best way to remove 8 x 4 12mm plywood that has been screwed down every 100mm on top of floorboards and then tiled over? Thought I had done the hard work getting the tiles off but these boards are a pitta. All the screw heads are covered and I cannot get a screw out as they just wear through.
Thank you
Thank you
