Help with simplifying Curves (Sketchup)
Slim
4 Feb 2006
Trossachs
I have been designing a small side table with curved legs. I decided to render it with podium to see what it would look like and noticed that my curved faces had been simplified into several small flat faces.
You can see the dashed lines on each of the legs where the curve has been simplified.
I wouldn't be bothered, but it is showing up noticeably when rendered, as each of the small flat faces reflects the light differently.
It wasn't like this yesterday. Is there a setting in Sketchup for this? Can I reverse this effect so I get a nice smooth flowing curves again?
Many thanks in advance.
Send me your SU model so I can take a look. I have an idea but need to see it to be sure I tell you correctly.
FWIW, SU always makes curved surfaces from smaller flat faces. It's just that you usually don't see them in renderings.
Actually, one question for you. Do you have Hidden Geometry turned on? I don't know what Podium does with hidden geometry if it is turned on. It may show it. You could try a quickie render making sure hidden geometry is not turned on.
By the way, that's an interesting table. Have you thought about drawing the curves for the legs with a 2nd degree Bezier curve?
Hi Dave,
I have turned off hidden geometry and the dashed lines disapeared, but the flat faces are still showing up when rendered.
I have emailed you the skp file. Is there not a way of increasing the number of faces that make up a curve?
Many thanks for you help.
Oh and could you expand on the bezier curve - I don't understand.
You can increase the number of faces, or rather the number of line segments used for the arc. When you select the arc tool you simply type the desired number of segments (sides) in the VCB and hit Enter. It'll stay that way until you change it. Be very careful with this however. You can quickly cause the size of the file to bloat and reduce performance on your computer.
I'll have to do up something on the Bezier curves for you. Do you have the plugin? If not, get it here
BTW, no email yet. Did you send it parcel post? :D
Yep, thats right. I have re-sent it.
I am reading up on bezier curves as we speak.
Ah ha! I have just seen the paragraph in your blog about the bezier plugin. So it's for creating curves that are not circular. That could be interesting. I will try it, thanks
Yeah Dave, I tried a render from a different perspective and the curves appeared nice and smooth. I'm not sure why.
Ah well, thanks for all your help. :D
