Hi,
I am restoring an oak dining table. I started sanding on 60 grit then worked up to 320. I sanded to remove previous finishes. Most of the table feels very smooth after the 320 but some areas feel rough. I noticed the areas still rough have fine kind of holes/pits/pores in the oak. I have attached a picture at a distance where this isn’t noticeable and one closer where you can see these rough bits. Why has this happened in some areas? Do I keep going and sand until they are gone?
Many advice is much appreciated,
