Help with Record DML 24X
eatsleepdrink
20 Jul 2014
March, Cambs
Hey all,
New to the forum and new to turning as well. Have been woodworking for a year and fancied trying turning.
I have bought a Record DML 24X all working, only problem I'm having is getting the part done bowl thats currently on there off.
I can see the flat section for the spanner I have but don't know if theres a way to lock it from spinning or if Im missing something really obvious :? .
I have attached a picture and any help would be really appreciated.
    118 KB
Hi
You hold the spindle still with the spanner on the flats you can see in the photo - then you spin the faceplate with the work attached anti clockwise, looking from the right, which will unscrew it from the spindle.
Regards Mick
Thanks for that.. managed to get it off in the end! Felt better knowing which way to turn it so i didn't get it stuck on there permanently! Turned a log round and get a a wood block rounded as well.. chips everywhere!
Or same idea but just a bit of plastic milk bottle or similar which may be easier to get your hands on.
Cheers, Paul
Thanks bigwing but that's not the manual just some miscellaneous blurb for it's successor the Mk II.
Having just got a copy of the manual kindly emailed to me by Steve I realise that what I'd really like to get my hands on is the service manual.
Hi Col, why do you need a service manual? There's not a lot that can go wrong, I've had one of mine for over 20 years (I've got 2) and not had a problem with either.
Steve
Hi Steve.
There's nothing wrong with the lathe I just fancied getting inside the headstock to adding a captive bolt and a headstock swivel but in order to do it I'd need to take the pulley shaft out and I wondered how difficult that would be. Not very - would be my guess - seeing as you have to do that even to change the drive belt, but one never knows.
Walney Col":zixdnji2 said:
JimB":zixdnji2 said:
I have the manual for the DML36SH but I doubt it has much more than the other one. 27 pages in all.
Hi Jim.
If it a pdf or a paper manual? Does it say anything about taking the driven pulley shaft out?
Pdf not paper and yes in section about replacing the bearings.
Steve (loftyhermes),
I know 2 years has passed since this was posted but I have just inherited a Record DML24X and while searching, for 2 days!, I came across this post. Is there any chance of a copy of the PDF manual you sent to chipswitheverything? The lathe is in great condition and I contacted Record to ask if I can buy a manual....but no reply (yet). My gratitude would be everlasting if you can help!
Thanks in advance, Dave.
