Hornbeam
I have a job which has some fluting so decided to buy a matching pair of wooden rounds/hollows.
They are the same maker and both are stamped as no16.. Bothe blades are 1 1/4 inch wide which corresponds to a No 16
I expected the sole profiles to be an exact fit, however the round is significantly tighter radius than the hollow.
Is this normal?
If not I could adjust one to fit the other but how do I determine which is a true 16 curvatur
Thanks in advance
Ian
Is this normal?
Thanks in advance
Ian
