Help re-sizing please
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
I'm obviously missing something that's very simple.
Say I create an object, 600 x 600 x 50, and then click the pointer or some other function. What's the best way to get back to re-size so that I can change it to 500 x 500 x 40?
I can re-size it with the mouse but I don't see the size in the bottom right as I do when I originally create it.
Thanks, in advance,
Neil
The thread Neil points you to should help you out so I won't go on about it here. Just a thing to keep in mind about SU, though, is that a tool will be active until you select another tool. If that tool includes the use of the VCB, the VCB will also be active until you click on another tool. Unfortunately you can't go back to it so you have to approach the change the method of adjusting. In some cases it might be easier to click Undo and try that last thing again. In others it might be easier to resize using the selection and Move tool or maybe even the scale tool.
Good luck with it.
Hi Dave and Gidon
Thank you for your help. I've got it working, it's just a little bit clunky.
I've finally remembered to bring my laptop home.
Neil
