Help!! Please. Lathe restoration project
ritchiewags
23 May 2008
Sandhurst, Berkshire
Hello All,
I have just bought a MK3 Larvin Lathe in desperate need of some TLC. It is a treadle Lathe. It does in fact work (turn), but is very rusty and neglected. I hope to restore it to it's former glory. I would love any information on this lathe and if anyone has any plans or manuals I would be happy to re-imberse costs to obtain copies.
regards
Rich
Hello,and welcome to the forum :D
Sadly,can't help with any info on the lathe,but would love to see it working.
Andrew
Hi Rich, welcome to the forum.
Don't know about 'Larvin' but try this link Larvic it may help you a little. It is also worth dropping Tony Griffiths an email to see if he has any literature on the machine. It's quite amazing what he has tucked away concerning lathes.
Welcome to the forum Rich, a picture of the machine 'as is' would be nice if you have a means of hosting it, then we will all know what you are up against with any little problems that occur.
A rough guide to your location in your profile may be fruitful to trigger help from nearby members.
Hi Rich, welcome to the forum,
Sounds like you have a really interesting project on your hands. Most of us on here use electrickery for power though there are some with pole lathes. As Chas said if you can post some pictures (try Photobucket we can give you instructions if you get stuck) there are a few engineers on here who could probably give you sheds loads of advice.
Hi All,
Thanks for the welcomes. I have updated my profile and hosted photos with Flickr. Following the guide in the forum they should appear below, hope it works. It did for the preview.
There is a label on the flywheel casing with "LARVI~ there is a tear at this point. I assumed it was LARVIN as a comment on the site suggested it was a LARVIN for disabled use? There is also a label with ACRES Ltd, Willington. I found this company (if it's the same) on the interweb and emailed them for any information. Hope the pictures help identify it to others.
I have started removing the rust from the toolrest and banjo. Lots of elbow grease and there coming up nice.
Will load photos as bits get done.
Richard
Hello All,
I have finished the first bit!, one of the tailstocks. Below should be a before and after shot. I've gone with a darker green ( had the pot of paint already). I've used both a dip and a paste rust remover (after lot's of elbow grease) and they've done a very good job. Next should be the tool rest and clamp.
I've managed to get hold of a few manuals and promotion material for the Larvic lathe and this has helped a lot in identifying the parts that weren't set up. I still have a couple of bits that I'm trying to work out their function. I'll get some photos and see if anyone out there can identify their use.
Size of that flywheel ! - i bet you get as many revs as a powered lathe !!
If you get the rest looking as good as that it's going to be a relly lovely piece of equipment. Better start excercising your legs though :lol:
Reminds me of Leonardo D Vinci's lathe, that ran with a fly wheel as well. Stuart King built one from the pland for Turning Show last year. Worked really well
Hi All,
Thanks for the comments and praise! Hopefully, the completed project will live up to it!
Next bit done! Below should be a before after shot of the tool rest.
I've used a Hammerite paint the texture helps hide any blemishes! I am now working on the treadle plate.
Hi Richard,
There was recently a post somewhere on here for one of these lathes for sale on Ebay. Just had a look but can't seem to find it now :roll: ! I remember looking at the pictures at the time, it was in much better condition than yours was.
Your doing a damn good job of cleaning it up though. I reckon it'll be better than new if you keep going like you have been so far!!!
Well done!
Richard
Well done Paul =D> =D> I knew I could rely on one of you guys to find it!!!
Maybe these pics will help Richard in his restoration task!!
Richard
Hadn't really looked at the Ebay lathe in detail before, but it, and the one being restored, are beautifully made and incredibly solid. Look at that bowl turning rest on the Ebay one; makes your average Aximinster job (and the one I've just welded up for my Mystro) look pretty feeble. Whoever got the Ebay one got a real bargain.
Guess it would be very easy to convert to electrical power, but it would be an awful shame to do it.
i have just bought a larvic lathe lathe that has been restored and converted to electric, It works great but I am having trouble identifying the spindle thread , Any ideas please, it is very close in diameter (if not the same ) as an m33 thread but with less teeth per inch . Help appreciated please Gary
I wouldnt hold your breath for a reply, the original poster has not visited UKW since 2008. have you read the link Tam posted?
http://www.lathes.co.uk/larvic/
