AJB Temple
Finely figured
Summary - the door springs open a bit rather than swings cleanly on hinges.
Back story. Bought an old oak studded door from side entrance of former Manor House. It's 30" by 78" and weights about 60 kg. I made and fitted the oak frame, which is dead on square. Could have done with making it 4mm narrower in hindsight.
I am using two heavy duty security hinges (the type with a pin that goes into a hole on the other side of the hinge leaf). (I've made and hung 12 doors in this place, but all of them have wrought iron work strap hinges - have not fitted one with this type of hinge for years).
The door opens and closes fine, but it springs open slightly when I close it, rather than staying shut. Each hinge is rebated into both the frame and the door.
I am assuming that I either need to shim the hinges, or cut the rebates deeper in the frame, but before I do something stupid I thought I would seek advice here. Normally I am not a dimwit, but I have got myself muddled here.
(The door is a nightmare to work. The oak is like iron. Fitted Banham locks and took me ages to cut the mortice slots to size. )
