jorgoz
Hello,
I would like to build a traditional japanese taikoa, or several, but am looking for different ways of making them. A small nagado daiko, http://users1.ml.mindenkilapja.hu/users ... -daiko.jpg
I have done straight sided stave drums, but taikos have a smaller top and bottom diameter as a middle diameter, like a barrel. Problem with wine barrels is that finding thick (1 inch minimum) barrels is very difficult and clean up is an absolute mess, not even talking about cracked staves, which you can't see on the outside when your buying a wine barrel.
Here's an overview of what a wine barrel type taiko building proses, http://www.stanford.edu/group/stanfordt ... ocess.html
Here you can see a couple of pictures of a taiko building course in Germany, a couple of photos show the staves and i think he bandsaws them but putting consistent bevels on them i've no idea (band sander, but sanding consistent angles ??) http://www.simonsen-holzart.de/workshops_taikobau.html
I would like to know how i can shape the staves, with the help of a table saw, if at all possible.
The staves need to have this shape and then bevelled on all sides, the sides are somewhat rounded, http://www.flickr.com/photos/33757485@N04/4311385776/
For bevelling there is an easy jig for a double tapered stave, but i the tapers to stop in the middle and i need to make the tapers on both ends.
I could work with straight sides, the outside will be rounded, but i would need to use thicker staves (40 mm ?)
Another problem is maintaining continuous fibres along the length of the staves. Many conga builders for example bandsaw the curve into their staves, but this creates stave of inferior strength, shortening the longitudinal fibres and creating lots of waste.
I'm thinking about a) laminating 3 10mm planks over a bending
mold or
b) steam bending 30mm wooden staves.
All very time consuming, so if bandsawing is the easiest and quickest then i must give the purchase of a bandsaw consideration.
Bandsawing conga staves : http://www.youtube.com/watch?v=T3hs_JVE9vo
Any ideas ?[/code][/url]
mold or
