Hi all
I've been asked to make an honours board (name board on the wall) and have been asked to use old roof beams from the building. There's bit enough of this wood to do the whole thing, so I have a solid wood panel to form the main face of the board, and then will use the roof beams to frame it. This is a little outside my expertise, so was hoping for some suggestions on how best to build!
- the roof beams are pine, installed in about 1910, so some have serious cracks down them. I'm planning to fill the cracks with black epoxy before resawing - is that the right way round?
- the panel is solid pine, about 4cm thick, and I'm nervous about wood movement affecting the frame. My original idea had been to construct the board in a similar way to a cabinet door, with the panel floating in a rabbet cut into the frame. I'm not a fan of this method given how thick the panel is, but can't think of another way of approaching it!
- the beams are relatively short, so won't span the full length of the frame needed. What do you guys think would be the most subtle way of combining lengths to make a longer piece for the frame? One option would be to make decorative 'blocks' that are spaced around the frame, which cover the joints.
Any help is much appreciated!
