Hello all, I have been trying to design a frame that is expandable. It will be used as a mould to make resin sheets.
It needs to start at the size of 30cm x 10cm up to 3M x 1M and able to stop anywhere in between Height or Length.
The design I have included has a routered straight cuts in the longer sides of the frame, so that the two shorter lengths can slide along it. Although this will not allow me to adjust the Height.
The design isn’t flat like it is pictured, I’m not able to draw things in third dimension.
Please let me know if you know a way of doing this, or if I need to give more information, thank you.
