EPDM rubber granules will be put in at a thickness of 4mm and then the wetpour Resin PU binder.What resin are you planning to use? And what thickness?
If its for thin sheet in epoxy, make the biggest size, pour your sheet and cut the sizes you need..... probably easiest
They will be made to the size required upon order, so the frame would be set to the size of sheet the customer would require
Which would be the best base plate to use? Assuming the resin would adhere to plywood, would a sheet of rubber over it be okay?
