markwalker84
Hi all,
Wasnt sure if this should live here as it's not (yet) a project.
Recently moved into a new place which has a few sheds, 1 1/2 of which I am using for woodworking.
Basically there is a storage shed and workshop shed.
Storage shed is going to hold the bulk of any material storage and "spares" which leave the admittedly small workshop for nothing but tools and workshopping.
Want to to do this properly and get the most out of the space so any thoughts?
Stuff I need to get in here:
Table Saw - DeWalt DW745. It's on a wheeled base at the moment with a short outfeed extension with router table, but considering rebuilding.
Band saw - On a wheeled base
Drill press - On a wheeled base (with a mortiser stored below - that thing is HEAVY!!!)
Belt / disc Sander (plus potentially a spindle sander and / or stand alone disc sander at some point)
Mitre Saw - Evolution sliding jobby. Needs a LOT of depth annoyingly. Currently on a mobile mitre saw stand thingy
Thickness Planer
Probably two dust extractors - a small vac + cyclone / thein separator for sanding / hand tools and a larger canister vac or chip extractor for the larger tools.
As well as some bench work surface I'd also quite like a larger assembly table style space - Thinking ~half sheet minimum which I might get an MFT style top for.
I'm considering moving the thickness planer to the mitre saw stand as it is the least used "big" tool and it can then just be tucked away when not used. The mitre saw stand rollers would also be pretty useful I think.
Mitre Saw is annoyingly deep so considering either:
Having it infront of a window so if I need to use it, just pop the window to allow the posts to move backwards!
Having it fold flat against the wall until it is needed
That's quite a lot to get into a relatively small space.
Having stuff on wheels I think is going to be key, but in terms of the static stuff - what would you guys recommend and where?
Any clever space saving tips?
What stuff should be at the same height as other stuff?
Generally any thoughts so I can make the best of this.
Thanks,
Mark
Thickness Planer
Thanks,
Mark
