Help identify an old saw
AVM64
1 Jul 2022
Scotland
Hi folks,
Wonder if anyone can give me some information regarding the attached saw ie make and type of saw.
I am also keen to restore it, but cant seem to remove the handle. So any advice on how to achieve this without messing it up, and where to get a new saw handle, would be much appreciated.
Regards
AVM64
    107.4 KB
    122.7 KB
Its a tenon saw with a steel back. I am not sure of the maker and have not seen the spanner trade mark before. Does the medallion on the handle have any name on it? Going by the style of it it could be pre WW2.
Regards
Do not try to remove the handle. That type of saw screw does not respond to being adjusted, most likely to strip or break the threads, and be unusable.
The "Warrented Superior" stamp usually means it is a second grade of saw. Perfectly good, just not sold as a premium tools. The rest of the stamp could just be a retailers mark, rather than manufacturers.
Emery Cloth/ wire wool the majority of the rust off, resharpen, and try, before doing any setting.
you could have a very nice tool there.
Bod
Hi Bod,
Brilliant - thanks for getting back to me. I will do as you suggest and see how I get on.
Many thanks
AVM
Regards
Hi John,
Thanks for getting back to me - no name on the medallion but I am going to have a go at cleaning in up and hopefully using it.
All the best
AVM
You'll need to learn to sharpen and set it if you plan to use it with a decent result, as a starter I would recommend you watch......
Crownshaw Chapman & Co. Made saws from 1870s to well into the 1900s. Barley's reference book says your style of spine stamp dates to c1880
Hi Kwigly,
Many thanks for getting back to me - that's unbelievable. Certainly going to make sure I look after it and get it back to working order.
Thanks for that
AVM
