dewi
- Joined
- 1 Oct 2007
- Messages
- 57
- Reaction score
- 0
My daughter purchased this fireplace for just short of four hundred quid (mad??) anyway I built the hearth and tiled the hearth and the walls - a you can probably see the rh side leg is 3/4" longer than the LH side - it is basically as rough as a badgers a**e - the filling between the timber is cement and some holes are also filled with it but she loves it so what can one do - now on top of the mantlepiece is a piece of oak the surface of which I have wire brushed then pressure washed then more wire brushing until it's clean
[/img]
now the "tragic" bit :roll: I have to get the oak the same colour as the rest of the [strike]trainwreck[/strike] fireplace - it has to be there because (1) it hides the tiles protruding from the top (2) to hide the 0-1.5" taper that shows along the tiles where the thing is twisted
then I have a slab of Beech that is 4" thick 30" wide 6' long that I have to get the hearth slab surround out of - she likes this because both the long edges are curved and gnarled and knotted (yet nice and smooth) this also has to match the fireplace when finished - but these faces have hundreds of wormholes that I have treated but now need to fill before staining/colouring and I dont know what to use for this - any help would be much appreciated
