dean0866
Hi,
I'm hoping someone can give me advice/direction in fitting an inset cabinet door into a face-framed cupboard I've built that has a bit of an issue. In my defense it's the first real bit of furniture making I've attempted and apart from this issue, it seemed to be going fairly well. Now, before I make the wrong decision and ruin it all, I'd appreciate some guidance on the best approach to resolving it.
The issue: The opening in the face frame for one reason or another isn't square in that I have a 2.5 mm difference corner to corner which is quite apparent when trying to fit the cabinet door. The resulting gap is clearly not correct to the naked eye in that the top left corner of the door is nearly touching the frame where's the top right corner has a couple of mm gap. The door is fairly square (read, first attempt at door making square)and I'm not in a position to dis-assemble the door, face frame or cabinet.
Notes: The hinges haven't been cut in or fitted to either the door or face frame and I haven't attempted or performed any corrective action so far......I've kept the plane/chisels etc away from it for now. The second door (the cupboard has two) is fine and fits square etc but again this hasn't been fitted yet.
Here's where I could do with some advice; what's the best way to resolve/remedy the issue so the door looks OK when fitted and I don't create further issues for further down the line. Do I:
1. Fit the hinges and plane the door to fit the opening so the gap looks to be similar
2. Plane the frame in order that the door fits square in the opening
3. Cut the hinges in to different depths to take out some of difference
4. A combination of all three above
5. None of the above and use a different approach
Each of my thoughts above I'm sure will result in other issues hence seeking advice and guidance first...
Thanks....
Thanks....
