SpursDave
Hello everyone I have a question - What is the best height for a table bench to use a mitre saw for repeated cuts?Obviously we don't want a sore back so should I be straight or just slightly arched to control the wood better?
Your bench and set up are a lot tidier than mine, but I'm wondering, are you left handed?The ideal solution is to mount the mitre saw on a lowered "shelf" between two normal height benches with the saw bed level with the benches either side - that way you have support for longer pieces being sawn, and the ability to fit a fence - perhaps with a rail and stops for repeat cuts. The pic shows my set-up (the box round the saw is to improve dust extraction into the ducting) - the fence on the LH bench runs in t-track and can be slid back or removed to use the whole of the bench.
Possibly the ideal height of your saw bench would be a ratio of your height. If you are 6' 6" you might not be comfortable at the same bench as someone 4'.Hello everyone I have a question - What is the best height for a table bench to use a mitre saw for repeated cuts?Obviously we don't want a sore back so should I be straight or just slightly arched to control the wood better?
I have the stops to the right of the saw. To me having them on the left would be weird.
I would be operating the saw with my right hand, so feeding in from the left, with blocks on the rightNormally a right hander will have the stops to the left of the saw.
Generally a right hander would hold the keeper piece against the fence and stop with their left hand while operating the saw with their right hand, the offcut then falls away to the right.
Same here.I would be operating the saw with my right hand, so feeding in from the left, with blocks on the right
I hold the off cuts, the keeper pieces aren't going anywhere jammed between the blade and the stop.Generally a right hander would hold the keeper piece against the fence and stop with their left hand while operating the saw with their right hand, the offcut then falls away to the right.
Im right handed, and have my stop on the left - the piece im keeping stays under my left hand while I hold it, and right hand operates the blade
I was wondering about that.AND before anyone asks I have to remove the box around the saw to make 45degree cuts -
