RosscoPCole
Hello everyone.
One of my Hegner saws has started to not switch on properly. When you press the on switch the motor hums as normal, but nothing happens. If you encourage it by manually moving the top arm it comes to life and works fine. I've made sure that everything visible is clean and nothing is clogged up. Not having much electrical knowledge I don't want to strip the motor then discover it is something else.
Any possible solutions will be gratefully received.
Thanks in advance.
Thanks in advance.
