mac1012
been tempted by a couple of ebay 2s scroll saws or buying a new one
I still not decided but came across some interesting conclusions when decided what I would gain if I upgraded from the base model
I long assumed that the base model was an 80 watt motor and the 2s is a 100 watt motor and when looking at the description on the hegner website it indeed says 80 watt for the h 1
but further down the page and on the comparison chart it states the base model as having a 100 watt motor
so only one way to find out so I looked at my machine motor plate and the heg 1 is indeed a 100 watt motor
I also realised the table size is pretty much the same size and if you look at the website the front part of machine to the blade is pretty much identical
I looked on the parts list and the pivot bearings are the same on both models
so what is different I hear you ask ? well the table is more square at the back but length and width at front are almost identical
the casting that holds the arms is bigger and higher to allow for a 5/8 increase in cutting thickness and the blue arms are longer and you get a 4 inch increase in throat
the quick release lever is at the front instead of the back and two stroke settings ( although I just realised the m 1 has two stroke settings 12mm and 15 mm) as opposed to 12 and 19 on the 2
enough difference to make me upgrade ? the jurys out at moment for my needs probably not
there is not as much of a upgrade as I thought I assumed the motor would be more powerful and the table wider they are the things that would have me more inclined to upgrade.
I give it some more thought 8)
