I have a small 6’x8’ workshop (shed) that is mostly insulated. I would like to store tools without rust being an issue. I think that maintaining a minimum temperature of 7-10 degrees would help with this. I don’t think a little tubular heater would be quite powerful enough do you?
I am considering getting a little oil filled radiator instead, should be safe to leave on its thermostat or even a plug thermostat don’t you think?
My question is……..as long as the heater can give off heat faster than the workshop looses it, does it really matter how powerful the heater is when it is effectively just maintaining a minimum temperature (I.e. speed to heat the space is not important). Surely a 1000w heater would just be on half as long as a 500w heater to maintain the same temperature and they would cost the same? You are ultimately just paying for replacing a certain amount of heat loss.
Also a physically small heater would give up heat to the space more slowly and would take longer to heat the space than a physically larger heater with the same power? So again, a small heater should be fine?
When I want to use the workshop I have a fan heater that works quickly to heat the space.
Would be interested to hear people thought on this.
