Following on from the rubik's cube workbench https://www.ukworkshop.co.uk/forums/viewtopic.php?t=31130.
The brief was; covered in same material as 2 existing chairs, white painted surround (I wanted to do it in berch and danish oil but was out voted !) with curved top, no visible screws.
This is what I came up with :-
I printed out a full size paper template of the curved top and used it to mark the outline on 19mm MDF. The rough curve was then cut out with a jig saw and a framework of 36x48 softwood screwed and glued around the perimeter. Around the curved top I used 23x48 weakened with cross cuts every 10cm. Using a hand held router the edge was trimmed down and rounded over. Here's the finished head board :-
Using the rough offcut from the headboard I made two MDF templates from the paper template; one of the outside curve and one of the inside curve. These were finished using a bobbin sanding drum in my pillar drill.
Next I marked out what would be the top part of the surround, also in 19mm MDF:-
After rough cutting out with a jig saw the MDF templates were used to trim the curves in the router table :-
The surround will have a curved top in 12mm MDF glued into a 6mm deep trench. I made the top in 2 pieces joined in the middle with a biscuit, and used the curve templates to cut the trench using a hand held router and a template-trim cutter. I had to weaken the top pieces with cross cuts to bend them to the curve. Here's the finished top part of the surround with the curved tops ready for glue....
...... and lots of clamps (bobbin sander in pillar drill in the background)
Next up is the sides of the surround - same construction method as the curved top, but hopefully a lot easier to make..................
