Phlebas
Burbling Pixie
MikeG.":110jro2m said:Excellent, Phlebas. Is that just a normal Stanley-like blade?
Droogs":zpso1db3 said:Thanks I enjoyed that, well done.
samhay":2mak64vk said:Very nice.
For someone who doesn't use dowels very much, could you describe how you manage to get 8 of them to line up nicely?
Sheffield Tony":177mk5zz said:Very nice, isn't it satisfying when it first takes shavings ... speaking of which, it didn't happen if there are no pictures ... we want shavings !
Liquid hide glue would make the job a lot less stressful. It seems to let joints just slip together. I have taken to using if for chair glue-ups after trying titebond and having a stressful time with a big mallet.
sammy.se":knfzquku said:Looks very nice indeed!
Did you get the opening for the throat right first time, or did you have to do lots of trial-and-error type dry fitting?
+1 for seeing the shavings!
thetyreman":60x835yt said:interesting design and very well executed, it'd be good to see it in action.
Phlebas":nnjuk2gx said:Briefly, veneer pins half driven into the centres on one side, the heads nipped off short, and the two parts clamped togeter in line, thus marking the centres on the mating part. Pull out the pins, and then drill with a pointy bit drill as serenely as you can.
That's how I did it any way. There are probably more elegant solutions. But they might cost more.
Orraloon":3sp4kmrx said:Nicely done. It's very satisfying taking some shavings on a plane you made yourself.
Regards
Hi, Sunnybob.sunnybob":1zdnx5ht said:from my extremely limited and ignorant viewpoint, I dont understand how you use that plane. The handle appears to be on backwards. Is it a push me pull you?
Sheffield Tony":d5fhpe39 said:Very nice, isn't it satisfying when it first takes shavings ... speaking of which, it didn't happen if there are no pictures ... we want shavings !
