Farmer Giles
The biggest tool in the box
Initially I wasn't going to post a WIP on here as it is so simple, however it has ended up that there will be a bit of a twist to it.
My eldest daughter wants a full room height bookcase with adjustable shelves "just like the ones in Harry Potter", After further questioning it could be the library at Hogwarts or Olivander the wand maker's shelves in Diagon Alley.
Her room has a reasonably high ceiling so they will be 2400mm high and the location is between a wall and a door frame and is 880mm wide. The bookcase is 200mm deep. The sides, base, top and shelves are all solid European oak to match the architrave and skirtings in her room. The back will be 7mm birch ply laminated with pippy oak as I acquired a couple of seconds sheets cheap. The middle shelf will be fixed and there will be 6 movable shelves on tonk strips.
So far relatively standard and I thought this would be an easy job so i got on with it. I used dominoes in its construction and I routed out the tonk strip with a trend router bit specifically for the job.
Sides cut to length, domino holes cut and tonk strips routed
Assembled and glued, just needed a little touch of diagonal tension to keep it square
Two coat of Osmo clear satin Polyx oil
The door frame architrave will hide the majority of the 7mm ply back. The rest I will hide with a bit of oak trim. I am assembling the back in her bedroom as it will be easier and lighter to handle or maybe in the spare bedroom. The ceiling is not level so I will hide this with a bit of sloping architrave around the top, or at least that was the plan
So I showed Lizzie the bookcase in progress. She said it was very nice but where is the secret compartment?! I thought, what secret compartment? But didn't say it knowing this would cause disappointment and although not specifically asked for of course I should know every Harry Potter bookcase has a secret compartment, obviously.
So I said that the secret compartment will be behind the frieze around the top. The frieze will have something like "Olivanders." carved into it and when you put your wand on or into the full stop it will release a catch and a shallow drawer will be revealed behind it. Once I said it I realised that I now had to do it as my daughters face had lit up.
So, the drawer will be about 80mm high, 840mm wide and just under 200mm deep. So I have dug out my Trend dovetail jig I bought or got given almost 17 years ago, I haven't got any further than assembling it yet.
In terms of the frieze, I thought I had best practice carving letters as I have newer done that before. I dug out some carving chisels I bought on an offer, could be Axminsters many moons ago, I was a couple of quid short of free P&P on an order and these were only a few quid so I they were almost free. Not the best quality of course but good enough for a few letters, maybe....
So after watching a few youtube videos, I selected a font, turned out to be Palatino Linotype
In retrospect, for a first go, a font with serifs and with variable width bits was not the wisest selection so I will not be using this for the job in hand, something simpler like Yu Gothic UI Semi-bold maybe.
However here is my first quick go with tools straight from the box with no honing, on well seasoned hard oak and without clamping it down.
I now have the next test bit on a carving vice (April Clearance, Rutland) and I'm just about to hone all the bits then try with the new font.
Andy
Andy
