Reply to thread
Hi everyone, I’d like to replace these old doors with new, but the existing door casings are way out of square and level.
The header appears to be about 7mm out of level across 60cm, and the top middle and bottom width measurements are 764, 760 & 770mm respectively.
I don’t see how a 762mm door will fit nicely in this frame, as 770mm gap at the bottom will seem to leave too great a gap.
Replacing the entire casing may not be straightforward due to the transom window, so does anyone have any advice on how to proceed? Thanks in advance!
