Togalosh
Hello Gents,
I've now develped "hand saw envy" from seeing jimi43's fabulous new addition but my budget won't stretch to such heights & I'd be scared to use it incase I scratched it !.. plus klaus might be taking a break.
..so I've been looking around for good saws but I've some qustions - as usual- as although I've books descibing tools they don't seem so specific. I know the basics like rip & crosscuting & why some are finer cutting/kerfed but I am not sure as to why there is such a diversity of saws that seem almost identical (online at least). I have been using a gents saw for dovetailing & disposable (?) saws for other jobs & they seem fairly average & I use power saws for bigger cutting. I am thinking of getting a Dovetail & Tennon saw but there's much more.
So:
Sharpening - will I need to become a saw blade specialist to be able to sharpen my own saw blades or do saw sharpening companies do a good & economical job instead?
How long will a good blade last in hobbyist use?
What are you your prefered saws that you use the most?
Do you really put down your X cut Tennon Saw & pick up your rip cut TS as you work a joint or make do with a less superior cut for some cuts by using the same saw? ( I am forseeing my own laziness & want to see if that approach is just not acceptable)
Why make a 14 & a 15 tpi/ppi dovetail saw ??
Can you recommend a book/books on tools that is so specific that I can stop asking so many questions all the time?
So:
