Stanleymonkey
I picked this up recently from Ebay. I liked the enclosed gears - useful when working with children.
I thought it had a flywheel and auto advance mechanism (which it doesn't annoyingly) It's just a large piece of wood for a manual advance handle.
The drill loosens from its mount and rotates 360 degrees. However - the handle strikes the mounting piece and then can't be turned. So the drill only works when vertical!
Questions
1) Does any one know the brand / maker? (There is nothing on the outside anywhere)
2) Why bother having a rotating drill - if it doesn't work when rotated?
3) Is it actually an easy remove set up / rather than the drill being able to rotate? ie easy to take the drill to a different stand or mount something else in there?
[I think this is unlikely - just trying to find alternatives to the rubbish rotation feature.
Questions
