Phil Pascoe
Fromey " a hollow ground bevel is easy to hone" .. ..this is heresy - go and wash your mouth out with soapy water!
No it's quite true.phil.p":3q55soyo said:... a hollow ground bevel is easy to hone" .. ..this is heresy - ....
Fromey":3jkzzk0x said:I think you can take hollow grinding in two ways. i) you hone only the cutting edge forward of the hollow and ii) you grind/hone down both the forward and behind sections, relative to the hollow, until you get a full flat bevel. Both i) and ii) provide some time savings, especially is you've started with a chipped or skewed blade, as Jacob says.
I suppose i) could technically lead to relative weakness behind the edge. The weakest point would be at the hollow's lowest point (i.e, the shortest distance from the back of the blade to hollow. However, the hollows you get from any typical bench grinder are extremely shallow and well back from the cutting edge. I can't see you ever snapping the blade through at that point! It's still many millimetres of steel. To do that, you'd have already disintegrated the handle of the chisel from your mighty Thor-like blow. Further, if you've put such a large secondary bevel on the blade such that it extends that far back to make the hollow a true weak point, it would be one mad chisel and you would have re-established the primary bevel long ago. Thus, I don't see this method weakening a blade operationally.
GazPal":tz3ljsm2 said:Bends and breaks do happen and most typically when using hollow ground blades where they're ground with too shallow a primary bevel.
bugbear":23bdto1j said:GazPal":23bdto1j said:Bends and breaks do happen and most typically when using hollow ground blades where they're ground with too shallow a primary bevel.
There's an obvious distinction between "hollow grinding" and "too hollow grinding". The former is a viable technique, the latter is (definitively) an error.
BugBear
custard":3drf7elt said:Richard Kell's honing guides are great for chisels, because they reference from the face.
bugbear":1q8h3e4a said:custard":1q8h3e4a said:Richard Kell's honing guides are great for chisels, because they reference from the face.
I''ll just point out, they're far from the only ones that reference the back, including the Veritas mk II.
BugBear
custard":1cicuswy said:The Kell guide registers from the cutting face, and then clamps from the edges, so there's no tendency to twist the chisel out of registration.
Paul Chapman":xjmldobp said:
