Hi all and happy new year ! I have an old Ingersoll rand bench grinder and looking to find a cbn wheel for it. It's a smaller machine and unfortunately do not have the original wheels to measure, but know its imperial sized. The wheel diameter is 6" and the bore size is 1/2" I'm assuming the width is 3/4 inch as a measure with calipers from the metal (cup ?) to the bolt is coming in around 18mm ish. Anyone know if a 3/4 inch wheel thickness be a standard size ? And know where I can purchase a cbn wheel with the dimensions as above ? The Axminster offering has a 25mm width and I wouldnt be able to fit the sides back on the machine at that thicknesss ! Thanks all for any advice.
