grain direction for scrolling a piece of sapele
devonwoody
11 Apr 2004
Paignton Devon
Which way should I prepare to cut this blank of sapele for a scroll sawyer?
Picture would be best viewed if rotated to the left. did it this way to fit forum requirements.
    96.6 KB
From the picture it would appear the long grain is from left to right and the cross grain from top to bottom so if it was me I would cut it as it now stands, again, if it was me I would get 4 pieces from that lump. When the projects are completed you should get a really good finish on Sapele.
Thanks Chippygeoff for your advice.
We are wanting to finish the boards at around 4 to 6mm thick so I am thinking around 10mm thick pieces not 25?
Didn't realise you were going to cut them that thin. I use 18mm thick in the main. Be careful after you have cut the boards as they may well warp being that thin, it's what I have experienced several times in the past with thin stock.
