I haven't seen those videos, but I'll take a look. The people you've mentioned sound like makers that I need to be aware of. Looking forward to seeing their work. I assume it's beyond spectacular.
What wood are you planing in your photos?
I don't have a problem using a cap iron, but I also don't throw a board up on the bench and start finish planing it without regard to grain direction or other issues, and I don't believe others do this either on a day in, day out, project in, project out basis. Doing it on test boards vs. cavalierly risking it on live project stock are two different things entirely. In short, it's not a licence to ignore grain, and to the extent it's presented as such I think is hyperbole bordering on something worse. I don't sell woodworking videos, books, or live instruction nor do I have a stake in developing an internet reputation or persona. My forum name, while coarse, pretty much says it all.
And as I said in my earlier post, a tear out free surface is not necessarily ready for a finish. That patch of tear out one managed to at least visually rectify with the plane is still likely to pick up stains, varnishes, and shellac differently. There are all sorts of considerations. A maker might well step back and believe a project's finish looks great when it is in fact objectively ghastly to somebody used to working to a higher standard.
Again, I think those proclaiming something as "finish ready" are usually applying oil or long-oil varnishes and in that process rub **** out of the wood but are blissfully unaware that the surface is no longer as it was "from the plane." In other words, "you can rub me now or rub me later but rub you will." I've burnished freshly planed and tear out free ash with cheap paper toweling and the difference in sheen and even chatoyance is nothing short of remarkable - easily an improvement over the planed surface in looks and tactile feel. There's a less than zero chance I would ever take this routine out of my bag of tricks, at least when dealing with ash, though I understand it is currently highly unfashionable to admit to using any sort of abrasive - even one as fine as this.
All this having been said, the differences of course may very well be in the eye of the beholder and documenting them in video and still photography requires more skill than the woodworking itself.
Sounds like yourself might actually be serious about this, if you're into a high standard of finish straight off the plane, as anyone with a plane would.
Though I don't see what the work has to do with anything, plenty of folks who've made spectacular work without knowing how to get the best from a handplane.
Fine for them, not for me for multiple reasons, like being a scrimper working pretty much exclusively reclaimed iroko, which can give one reactions.
Scraping this stuff to dimension it is a recipe for having issues, and it's mighty hard work to boot,
having to reform the edge with only a minute or two's work, a real hog compared.
I used to put those pieces aside, as it appeared they needed to be scraped, or insert fancy "type 2" wimpy shaving with tool of future wallet/time expenditure.
Now I go out of my way to try find those densest examples, and no issue planing those,
It's these timbers in which the close set cap iron shines most brightly,
and seems from what you're saying might well be beneficial to you since you mentioned risk,
which isn't an issue for someone who's thoroughly familiar with how effective the cap iron is.
I didn't say I know everything, and am always questioning Warren who actually uses his for this purpose.
He actually makes a rounded profile on his to around 80 degrees, and is the only one I believe who likes it that way,
I find it interesting as I might try getting used to 60 degrees rounded bevel, as I've got some other rosewood like exotic in which the smoother cap needs set extremely close, beyond 1/64" which seems a bit OTT to me, if one can have it further away from the edge, they can have more camber if they want.
This isn't a very talked about subject, and most of the talk is folks speculating, cuz we all don't have the kit to make a few cap irons to compare.
I have absolutely no bother honing a steeper angle on the cap irons, should I need.
but I haven't found a piece of iroko which complained with 50 degrees on the cap iron.
Easy for me to do if I need more influence, and for it not to seem like some toe curling affair,
wondering if this is a good idea or not.
That's where one has to believe...or nowadays need to see to believe,
which sorts the men from the boys, doesn't it
Enjoy watching
Tom
