Richard Findley
Hi all,
There has been a lot on here recently regarding grinding and sharpening of gouges etc. I thought I would post a picture of my gouges and their grinds. Perhaps others could do the same and we can compare and contrast? I know every one does it slightly differently as turning is quite a personal thing. I thought it may help some one, some where....
My gouges:
This shows my "long grind" 3/8" bowl gouge, which is not that long compared to some. Ground at around 65deg
The second is my other 3/8" bowl gouge ground to the same angle but with a secondary grind angle to assist when cutting around tight corners. Here is a close up:
The third is my 3/8" spindle gouge, ground to around 35deg with a similar "long(ish) grind"
Finally my spindle roughing gouge ground straight across and again at around 35deg.
All are ground using my new 8" slow running grinder and tilting platform:
Cheers,
Richard
My gouges:
Cheers,
Richard
