mailee
Hi guys. I am having a bit of trouble with a 'new' dovetail jig I am trying to use. The jig is the Nutool 12" one with a template that states 1/2" on it. I was given the jig without a cutter and guide so bought one from Axminster for there machine which also stated it was for the Nutool. It comes with a bearing already fitted to it. I set up the cutter and jig as per the instructions and all the joints were too tight. So tight in fact that they wouldn't even start! I raised the cutter as the instructions stated and they were still too tight! By the end I had raised the cutter so much that the bearing was just touching the top of the template and it was still too tight! I can't raise it any more without cutting into the template now. As a test i took the bearing off and just used the collar and ran this around the template and low and behold they fitted just a little slack? The bearing is the one stated at 12.7mm but the collar is way smaller than this! Anyone any ideas what it going wrong?
